We just purchased Intelligence reporting, and I cannot find any training videos or manuals. The ones I do find, from years ago, have links that are no longer available, or they take you to sites that do not focus on Intelligence reporting. I would really like a top-to-bottom training!
thanks
Kim
I Concur! I need this too.
@KimB123 and @RavenClaw take a look at this link: https://community.concur.com/t5/Reporting-Hub/Explore-Available-Intelligence-Cognos-11-Training-Sess....
I think you will be happy with what it talks about. 🙂
Thanks, that's great! I see the courses available! However, the one English version is on 11/25/25, and I may not be able to watch the entire course. Who can I contact to get a recording of it? Also is there a manual I can refer to, in addition to the courses?
Thanks so much
Kim
@KimB123 I don't know if the reporting team provides the recordings of these classes to those who are not registered. If at all possible, I would try to attend the session. It isn't very often you get a live class on reporting that is free. 🙂
You can also try sending a private message to: @dbrandywatling to see if she can provide some resources.
Thanks @KevinD ! I looked at the schedules and I cannot attend the English ones due to timing. Are there any resources or repository for previous recordings?
@RavenClaw I see you are a member of the Data Services Connection group. I suggest posting there and tagging @dbrandywatling as she is the owner of that group and can help you with all your reporting questions. 🙂
Please let me know if you find any previous recordings, as I have the same issue with the date.
thanks
Hi @KimB123 , I spoke with Kathleen, who hosts those live trainings. She said if you register for the class and cannot join, you will have access to the recording. Feel free to send me a message if you have any issues and we will work with her to find a solution for you.
thank your so much!
Good day!
I am waiting for live webinar training schedule for Cognos 11 Report Query. Do you have an upcoming webinar for report query training? Please help me access the old recordings for this report query if you have any. Thank you.
best regards,
Belinda Esguerra
