In the new version of the mobile application, a "+" button has appeared in the travel section. But when I press the button below a blank screen appears that only allows you to cancel. It's happening on both iOS and Android device.
Why can't we book travel from mobile?
My enterprise has the 3 SAP Concur modules: REQUEST, TRAVEL & EXPENSES.
Thanks for advance,
Josep
Best Regards,
CJ
@cjmarimo Hello! I am sorry for the issues you are running into with the Mobile App. I see you actually created a Support Case and they provided this: At this point of time, booking a trip in Concur Travel from mobile devices is not supported when you have Concur Request module enabled.
Let us know if you have more questions!
