ThauanyMoore
Assistance Creating Custom Concur Intelligence Report for Reconciliation
I am currently using SAP Concur Intelligence (Cognos 11) to support monthly reconciliations. The standard reports available to me (such as Credit Card Transactions) provide useful card transaction information but do not include all of the data required to complete the reconciliation process in a single report. I am looking to create (or obtain access to create) a custom report that combines the following information.
  1. Report Name
  2. Report Status
  3. Business Purpose
  4. Engagement Number
  5. Internal Order
  6. Allocation Code
  7. Allocation Description
2 Solutions
@ThauanyMoore of the items you listed, you can use the Search option that appears above all the data items to find everything in your list except number 4 and 5 as these are custom to your company.
You would need to use the Configuration report or Forms and Fields to see which generic field labels are being used for Internal Order and Engagement Number. They likely will be found under data item labels such as; Custom 01, Custom 02 or one of the other Custom data items. If you don't have access to the Configuration Report or to Forms and Fields, the other options you have are:
1. Ask your site admin if they can look these up for you.
2. Build a new report, add several of the Custom data items to the report, then run the report to see which one shows Internal Order and Engagement Number. It is a bit of trial and error. Once you find them, make note of them for future reference.
3. Ask me if I would be willing to look these up for you. 🙂 I'm usually in a good mood on Fridays, so the chances I would do this for you are pretty good.
@ThauanyMoore you can do all of that with Intelligence. However, identifying charges that should have been on a personal card can be challenging if users are not marking these items as personal. How would one know the charge should have been on a personal card by looking at the expense entry details?
Also, what determines how a user should allocate their expenses? Do you have projects that employees work on and charge expenses against? Also, if am in lets say the Marketing department, what types of expenses and situations would allow me to allocate or charge my expenses to another department or cost center? There needs to be some sort of identifying data item entered onto an expense report that would make it easy for those running the Cognos reports can see to make sure the expenses were allocated/charged correctly.
13 REPLIES 13
@ThauanyMoore my one question to those who post questions about building Cognos reports is this...What is your level of Cognos report building experience on a scale of 1-10? A 1 would be "what is Cognos?" to a 10 that would be "I can build Cognos reports easily".
Where would you say you fall on this scale? Also, two of the data items Engagement Number and Internal Order are custom fields, so you would need to know which fields were used to capture this data. You would need to look at the Configuration Report or go into Forms and Fields (if you have access) to see what the default field labels are. Are you familiar with the Configuration Report and/or Forms and Fields?
I'll await your reply and then go from there. Oh, one other thing...have you attended any of our Free Cognos webinars?
jusher
Please can you tell me how we access the Cognos Webinars, we are really struggling to build any reports at all.  We have been asked to identify spend by expense type and employee which I thought would be a standard report, but does not appear to be available.
@jusher here you go: https://community.concur.com/t5/Reporting-Hub/Explore-Available-Intelligence-Cognos-11-Query-Studio-...
I think once you take this class, you will see that showing spend by employee and expense type is a pretty straightforward report to build.
If you look in the Standard Reports folder there should be two reports in there that should give you what you are looking for: Expense Entry Analysis (grouped by Employee) and Expense Entry Analysis (grouped by Expense Type). Give those a try.
ThauanyMoore
I would rate myself as a Level 3. I know what Cognos is and have been exploring it, but I still feel that I haven't been able to find the answers I'm actually looking for. I participated in a webinar and found it helpful; however, some of the features and options that were demonstrated were not available in my environment, which made it difficult to follow along and apply what was being shown.
ThauanyMoore
Thank you so much for the detailed response! I would absolutely appreciate Option #3
Could you please help me look up which generic Custom fields map to "Internal Order" and "Engagement Number" for our configuration?
For context, I am trying to build a custom List report in Cognos to automate my monthly AMEX reconciliations so I don't have to manually combine standard reports anymore. Along with those two custom codes, my goal is to pull the following standard data items into one clean view:
  • Vendor/Supplier Name
  • Transaction Date
  • Amount
  • An indicator showing if a charge is a "Personal Expense" (I believe this might just be the "Expense Type" field, but any confirmation there would be greatly appreciated!)
Thank you again for offering to look this up for me—it is a huge help!
@ThauanyMoore the fields are Custom9 and Custom10. However, you must pull these data items from the Allocations folder in the data warehouse or else no data will display.
ThauanyMoore
Thank you. I’ll definitely be diving deeper into the customization options.
In the meantime, I was wondering if you might have some availability for a call with me and my manager. She has a few questions, and I was wondering if we could discuss them with you directly and get your insights.
@ThauanyMoore unfortunately my role doesn't allow for customer calls, but I would be happy to look at your manager's questions if you provide them to me in a private message here on the community. That would actually be better as then I can have more time to provide the best answer rather than have to come up with a answer on the spot.
To send me a private message, click my username (KevinD) then the Message button.
ThauanyMoore
Thank you very much.
Will do that, in the meantime I do have a question:  When we are in Concur under Expenses > Card Transactions, where we can view the card charges, is there a way to export that information directly to Excel?
So far, the only option we have been able to find is saving the page as a PDF. However, to capture all of the columns, we often have to reduce the browser zoom level or resize the screen significantly, which can be challenging and does not always produce the best results.
Would you happen to know if there is an export-to-Excel option available, or another recommended way to extract that data?
Thank you for your help.
Thauany
@ThauanyMoore on that screen, there is not export to Excel option.
Why do you need to export it to Excel? Most people won't have that many charges showing on this screen if they are being timely in their expense reporting.
ThauanyMoore
Thank you for confirming.
The main reason for this process is that we are required to complete a reconciliation each month. The primary objective of the reconciliation is to verify whether any charges were inadvertently made on the company card that should have been paid with a personal card. In addition, to review if the expenses have been charged to the correct expense codes and to identify any reallocations that may be needed at month-end. Is that a way we could do that withing the intelligence report?
Thank you, Thauany
