DCormier
Unlock Feature for Passwords instead of a reset
JessicaL
I'm going to Fusion
I'm going to Fusion
Re: Unlock Feature for Passwords instead of a reset
Jessica
Maybe there are security issues with allowing an unlock. I'm guessing here, but seems like a plausible reason why there isnt' such a feature. :-)
DavidW
Consider using Single Sign On (SSO).  This way, they don't need a separate password for Concur.
kirstin_rintoul
I also can't believe that admin don't have this function!  We are about to go live and have encountered this issue with an account that has been set up to use for our video production.  We now have to delay - this should be a standard piece of functionality that Admin are able to override the lockout.
