Hi All,
As i knew, to customize report in Business Intelligence (IBM Cognos 10.2.1) which it is supported for Internet Explorer 11 in Compatibility Mode currently.
Based on the MS's info, on August 17th, 2021, Internet Explorer 11 will no longer be supported for Microsoft's online services.
What is the next plan for SAP concur to process with BI report?
Thank you and regards in advance.
Tookta
@tooktamv we are currently working on upgrading to Cognos 11, which will be compatible with other browsers. A couple of things though:
Suffice it to say, it is on our Roadmap. I also must say, that these types of updates can change at a moment's notice.
