tooktamv
SAP concur -> Business intelligence - Web browser to be supported when IE not supported by MS
Hi All,
As i knew, to customize report in Business Intelligence (IBM Cognos 10.2.1) which it is supported for Internet Explorer 11 in Compatibility Mode currently.
Based on the MS's info, on August 17th, 2021, Internet Explorer 11 will no longer be supported for Microsoft's online services.
What is the next plan for SAP concur to process with BI report?
Thank you and regards in advance.
Tookta
@tooktamv we are currently working on upgrading to Cognos 11, which will be compatible with other browsers. A couple of things though:
  1. Currently, the Query Studio tool will only work with IE. This is an issue as we know, but we aren't sure how to get around this as it is more of an IBM Development thing and not on our end.
  2. We are not sure yet on the time frame of rolling out the Cognos 11 upgrade. Not all customers will be upgraded at the same time. With having almost 30,000 customers on Cognos, the process will take some time.
Suffice it to say, it is on our Roadmap. I also must say, that these types of updates can change at a moment's notice.
DeanR
Hi @KevinD ,
Is there any update on this?  Our  Cyber Security team has decided to get ahead of the curve and remove IE from the end of the month, so I'm facing having no ability to edit our custom reports or create new ones. 😬
Migrations are slated to start later this year. However, dates are still tentative.
I believe Firefox should allow you to edit your reports.
Can you give Firefox a try and let me know if you are able to edit your reports, please?
DeanR
I'm working with our IT department about an alternative with Firefox for now - it's not a browser that is normally installed and I don't have local admin rights to do it myself.
Thanks for the update 😀
Nancyagfa
I also had questions on retiring IE and the change to my reporting abilities.  Based on the above, I opened one of my report with Firefox and it appears to have the same format as IE.  I will be trying this as the alternate as they phase out IE.
@Nancyagfa Firefox should work as an alternative. When we update Cognos to version 11, other browser should work, except with Query Studio, as far as I've been told.
