In Concur, Admin, Company Admin, there is an Administrator Approval Queue and I was curious to find out what this is used for? Is this mostly for temporary changes or can it also be used for permanent changes?
@randimoore This screen is used to reassign an approval to a different approver when the assigned or default approver isn't available.
For example, Manager A goes on vacation and forgets to set up an approving delegate. The Administrator Approval Queue will allow you to assign items in Manager A's approval queue to another manager. I believe this is a one off and not a permanent.
Thanks Kevin
