DavidW
Reporting/Intelligence is timing out
We have been getting a "timeout" in Intelligence since last week.  Anyone else running into this issue with their Concur reports?
This happened 2 months ago, and Concur was able to determine a server/load balancing issue.
Thank you in advance.
DavidW
Thanks Grant.
That helps. We had Concur reporting services take a look and with the rebuilt reports the issues appears to have gone away.
14 REPLIES 14
