sreeleshskumar
Is it possible to get a count of Users who have been linked their Concur App with Uber in an org?.
HI All,
How can we get a count of users who have linked their Concur APP with the Uber? Is this something possible? A count or a percentage?
Routine Member - Level 3
Re: Is it possible to get a count of Users who have been linked their Concur App with Uber in an org
Hi there - we took up Uber for Business in April this year.  It automatically links to SAP Concur Expense once the end user sets the U4B app up.  We found uptake of U4B in our organisation was close to 25%.
Kind regards
Richard Grigg
Also if you are an administrator with Uber for Business in your organization you do get a visual on all active users as well as all work trip activity.
Hope this helps
Richard Grigg
tjbmoreno
Agree with @RichardG. You can view from the U4B portal. The problem we are having is getting employed to set up separate personal and business profiles, and even if they do, remembering to change profiles accordingly.
Terri Moreno
Hi @tjbmoreno - the U4B platform allows you to set up prompts to alert employees partying hard on a Saturday night that they are still in their Business profile and asks them to confirm if the trip is business related.  Since transitioning to U4B from the basic app we went from 30 cases of profile misuse to nil!  The only problem is U4B hasn't got the same prompts for Uber Eats - so now I get to see who can't cook to save themselves in the organization!
They are working on a fix though.
Kind regards
Richard Grigg
tjbmoreno
Wonder if it’s different in Oz?
We only have one Uber app. There’s not a separate app for business, just add a business profile to the existing app.
I’ll have to check the portal as well to see if I can figure out that feature.
Thx @RichardG!
Terri Moreno
@tjbmoreno - they released it the week before Fusion!  I rejected their first U4B model because the transactions bypassed Concur Expense.  I approached the Uber booth at Fusion to complain about transactions not going through Expense and they told me it had just been fixed - I got home to Oz and the transition took less than a week!
Richard Grigg
tjbmoreno
Gotta check it out! Thx!
Terri Moreno
sreeleshskumar
How can we get that info as you said the percentage of users linked their Concur app with Uber?
Can you please guide me on the same? How can we get access to the Uber portal? @RichardG
Hi @sreeleshskumar - firstly you need to get the Uber for Business module and have Admin access - you will then be able to have access to who has downloaded the app and who is using it.  Contact your Uber rep and they should be able to quickly set you up.
Kind regards
Richard Grigg
