Re: Concur Mobile App Log in not work
Same issue as others have mentioned...  I've been using the Mobile App for three years without any problems...until yesterday.   I can not log in to my mobile app.  I can log in online, and my account still shows that it's linked to my mobile app.  When I attempt to log in on my mobile device, I just get a message:  "Unable to Sign In  We are unable to sign you in with this information."  I've uninstalled and reinstalled the app twice with no luck in logging in.  I am traveling next week and need this resolved before then.
I am having the same issue on the mobile side. I have co-workers with no issue.
Any suggestions?
Thanks for posting!
I would suggest contacting your company's support channel. They would be able to help you look into this. In the solution on this thread, I have shared a few ways to best get a hold of them.
Please let me know if you have any other questions.
Edit:
Hi @andykrawchyk  and @AnnaLo ,
This would also be my suggestion for you all as well. Creating a support ticket will not only help you get this resolved but also make sure you have the latest information on when an overall fix is to be released. Our support teams are the right group to work with.
I hope this helps!
Ashley Bragg
I along with many others are having issues logging into concur mobile.  I have already reinstalled the app 5 times.  I went to my concur administrator for my company.  They talked to concur and were told to have me change my mobile pin or password which i have done and i have not been able to log in.  I travel exclusively for work and this is a major inconvenience for me and many others.  What can you do to fix this problem?  As i've already tried several things and i am still unable to log in.
Concerned customer,
Andy Krawchyk
Good morning,
We are facing the same issues on work mobile phone (ios), on the web it works.
Please could you give us any advice to fix?
I already reset password, re-install app without success.
Regards
Anna
hi there
I was talking to my colleague Jochen got the problem resolved by Valeria Knoblovits who eventually understood she had to get in touch with the Nokia IT team
@emadili wrote:
Any update  still no solution!
at Nokia, then wipe my user profile for me to then register again and get through the normal process.
Can you please do the same for me?
also Jerry Schu was involved, it was a chat on 11712/2019. Please advise if I need to open a dedicate case, or staying on this chat/blog is still ok
Hi @emadili
Please reach out to your company approved support channel to get assistance with this issue. Though the community can offer support in a variety of topics this one is best handled through an official support channel.
 Here are two ways to get support:
  1. You can contact your company’s authorized support contact. They will be able to help you create a support ticket for this issue. Your company should be able to tell you who they are and provide contact information.
  2. If your company subscribes to User Support Desk you can call them directly and create a support ticket. Your company will be able to tell you if this is an available support channel and provide you with the number.
Ashley Bragg
