Shon
App will not load since iOS update
App will not load since iOS update 10-18-2018.
I have tried to uninstall and reinstall all, same problems. Anybody have any pointers?
1 Reply
Josh
Re: App will not load since iOS update
Hi @Shon,
I'm running iOS 12.0.1 and Concur app version 9.61.1.1809270817, and the app is working normally for me. 12.0.1 was released on October 8th, but 12.0.1 (beta 4) was released on October 15th - is your device running the beta? If so, you might need to revert to the standard release, as the Concur app may not be 100% compatible with the beta version.
Josh
