I'm trying to forward an itinerary to [email protected], but keep getting a failed delivery response:
Is this no longer an option to have itineraries added to their profiles?
I have already verified my email address in my profile, and I am able to email receipts successfully to [email protected].
Thanks in advance!
Robin
@rchang the email address: [email protected] was retired back in July of this year. Going forward you can send itineraries to [email protected]. You can set up a free TripIt profile and link it to your SAP Concur profile. When you log into SAP Concur, you might see a section labeled Alerts on the home screen. If you do, there might be a message about signing up for tripit.
Let me know if you see this or not.
Does the traveler have to have a TripIt account for this to work?
@dannbrown yes. If you sign in to SAP Concur, you should see an Alert section. In there you might see the option to sign up for TripIt. Using this option allows you to set up a TripIt account and link it to your SAP Concur profile.
Thanks Kevin - if a traveler doesn't want to sign up for TripIt is there a way for them to send third party bookings to Concur?
@dannbrown not that I'm aware of. They should be able to go to the Travel tab and manually enter in the trip details.
May I ask, what is the purpose of them wanting their trip in SAP Concur?
