knefnifi
connect to AWS API URL failed: NIECONN_REFUSED(-10)
Dear all,
since this morning we cannot connect to "eu2.api.concursolutions.com" and we get the error below
Direct connect to eu2.api.concursolutions.com:443 failed: NIECONN_REFUSED(-10)
Anything has been changed in the AWS API URL for Europe?
thanks for help
knefnifi
@KevinD , I think I have found the solution when done “telnet eu2.api.concursolutions.com 443” I get no connection. the problem is on the firewall that block the connection. I have requested network team to adjust firewall and waiting for their feedback.
Many Thanks,
@knefnifi have you submitted this to Concur Support? That would be my suggestion.
knefnifi
Many Thanks,
