Hello, the name of the first people in the validation process is wrong. It's not my manager ...
Do you know how to update (or to solve) this issue ?
i'm looking for a people to update this information ...
@j553591 check your Private Messages.
Hi @j553591 ,
Please recall your report and reach out to Concur administrator or raise an IT support ticket to get your manager name updated in your Concur profile.
Once manager name is updated, you can recall your report and re-submit so that it will get routed to your manager for approval.
Thanks Pooja, but do you know how to find the name of "Concur administrator" ?
For your information, IT support is not available for this issue because CONCUR is not a STELLANTIS application
I try the HR service but no answer at this time ...
Hi @j553591 ,
I won't be able to check bcz I don't have access to your site.
Let's take Kevin's help here. Currently he is OOO from 17 to 22nd December. Let's wait for one day.
@KevinD - Can you please check and share Concur administrator details.
Hello, Thanks a lot. Issue solved.
