I need to unlink my old Concur account from my Skymiles account (among others) but I no longer work for the company that used Concur and that company no longer uses Concur either. Who can I contact that can help with this?
@Stacks this might be a bit difficult with your old company no longer using SAP Concur.
When you say you need to unlink, do you mean just remove your sky miles number from the profile or did your company use our TripLink option and you linked your profile to our TripLink service?
Hi Kevin, thanks for the quick reply. I don't believe they used the TripLink option.
When I login to my Delta account I have a Business Profile with the name of my old company, and although it's probably not an issue if they're not using Concur anymore, I don't want there to be a way where they can see my travel reservations if I accidentally click on the business profile instead of personal.
@Stacks are you not able to edit your business profile when on the Delta website?
I don't imagine anyone could see your reservation details if your old company no longer uses SAP Concur.
Thanks Kevin and sorry for the delayed reply. No sir, Delta was unable to help me; I was told to remove my skymiles number from my Concur account.
