- Mute
- Subscribe
- Bookmark
Second QR code generation
Hi all.
I have 2 way factor configures with my mobile phone and Microsoft Authenticator. IT works pretty well but I would like to have it configured on YubiKEY as well.
Is there a way to generate QR code for the second time?
- Mute
- Subscribe
- Bookmark
Hi @PiotrW !
SAP Concur does not natively support Yubikey for multi-factor authentication (MFA).
Best wishes,
Andras
- Mute
- Subscribe
- Bookmark
True, you are absolutely right.
But Yubikey Authenticator can generate "answer" otp codes.
Simply - I d like to have more than one device which is able to generate OTP password
- Mute
- Subscribe
- Bookmark
@PiotrW if your other device has the Microsoft Authenticator app, you can use the same QR code on more than one device. However, since you already set up the 2FA, you would need your site admin to reset your 2FA, start the process again by having the system generate the QR code. With the code displayed, scan it with the authenticator app on your first device. This will add the account to the authenticator app on that device. Then scan the QR code with the authenticator app on the second device. The system doesn't track if the QR code has already been used. The QR Code is simply used to add the account to the authenticator app. I have Google Authenticator and used one QR code to add the account to the app on my phone and to add it to the Google Authenticator browser extension. Works perfectly.
