Looking for help on the following;
- Is there any way to retrieve a report that would show who and how many people in the org are using Concur mobile?
thank you
@carycasas In Cognos reporting there are two reports based on Mobile. One is the Mobile Adoption Report and the other is the Mobile Metrics Details. You can try running each of those and see if it is what you are looking for.
Hello Kevin, I appreciate your response and indeed it worked as a charm. However, being knew to Concur I didn't know where to locate the Cognos Report. Adding this information would have been helpful.
