rameshsathyamo
Register Partner Application
We need to set up a new user in Concur with the necessary permissions to use data extractions to Celonis. The steps are mentioned below. But when I login to SAP Concur with my login I don’t see this option “Register Partner Application”. Can you please advise how to add/enable this option to my user.
When i Login into Concur with my user – Not able to find this option “Register Partner Application”
Your input is highly appreciated.
thanks
@rameshsathyamo did you try the Manage Application Connectors option?
The steps you have may have changed slightly.
