moening5
Number formatting for Intelligence Report
Is there a way to format negative numbers to appear as red text in the Intelligence Reporting tool?
@moening5 hello there. I found out the answer and it is yes. You can use what is called a conditional style. I did a little video capture of me running through the steps. I cannot attach an .mp4 file so I will email it to the email you have here on your community profile.
@moening5 I reached out to a reporting colleague to see if this is possible. If anyone knows how, this guy will.
moening5
Thank you, Kevin. Your video worked great!
@moening5 great. Don't tell anyone, but I used CoPilot and it spit out the instructions. 🙂
