jausborn
No notification emails for Request Status changes
I have checked that I would like to receive email when the status of a request changes and when a request is submitted for approval under Request Preferences in my profile.
I don't seem to receive any emails. The status of two requests changed multiple times a couple of days ago as per the Audit Trail, but I wasn't notified.
I have checked my spam folder, my email is correctly listed under Email Addresses, and the email is marked as "verified".
Thank you for your help.
Vijarchana
Hello @LovelyAsmolo,
Yes, kindly check whether emailing service is enabled. Usually, it is enabled after the setup is moved to PROD. But yeah, you can check once with SAP.
@jausborn I think there is an issue with the notifications as you are the second person asking about this. However, sometimes a company has not added emails from concursolutions to the allowed sender list. You can try reaching out to your IT department and ask them if emails from concursolutions should be coming through.
jausborn
Thank you for your reply, the emails should be coming through according to IT. What else can I do to get this resolved?
Kind regards, Jessica
LovelyAsmolo
Hi @KevinD , I am working with a client who is using production environment for testing notification. unfortunately, there is no notification receive by the employees. we asked Concur already and they said that notification is sending. is there an email notification enablement needed in Concur?
Vijarchana
LovelyAsmolo
Thanks @Vijarchana  😉 big help
