Trinetra
Need specific values for Concur and IAG Integration?
Hi Concur Team,
Can anybody provide me or guide me how to get values for the below properties in Concur solution. This is required for Concur to Identity Access Governance Integration.
Client ID*                                     <Enter the generated Concur Client ID>
Client Secret                               <Enter the generated Concur Client Secret>
Token Service URL Type*        Dedicated
Token Service URL*                   <Enter the SAP Concur token URL>
CompanyEntityCode                 <Enter the registered Company Entity Code from SAP Concur>
CompanyUUID                           <Enter the registered Company UUID from SAP Concur>
RefreshToken                             <Enter the generated refresh token from SAP Concur>
Trinetra
@Trinetra hello there. I think your question might be better submitted to SAP Concur Support directly. It seems pretty technical in nature and sounds very specific. I'm not sure how many people here on the Community would know about this.
I guess we can see if anyone else responds. 🙂
BavinKS
As far as my knowledge, SAP Concur didn't support IAG roles integration all these years. @Trinetra  are saying SAP has confirmed that IAG now supports SAP Concur? Please confirm.
Anyway, please see responses below for your queries:
Client ID*                                     This is your Concur company ID, Concur support admin can provide.
Client Secret                               you can find this under Admin -> Company -> Webservices -> Register partner applications -> click modify the current registered item and scroll down to bottom.
Token Service URL Type*        Can be found under Authentication admin
Token Service URL*                  Can be found under Authentication admin
CompanyEntityCode                 Entity code of your Concur instance -> contact Concur support
CompanyUUID                            contact Concur support
RefreshToken                             contact Concur support
@BavinKS the support of IAG roles integration isn't something I am familiar with.
BavinKS
@KevinD  IAG based integration helps to seamlessly establish interface between on premise and cloud platforms (Between SAP and any cloud applications) where earlier we had to use an o premise middleware such as PI/PO etc for the connection. For Concur I have started hearing this is supported nowadays, however no clarity.. let me research and get back.
LMAG
Hello ,
When trying to provision access  form IAG to existing user in Concur getting the below error.
Please suggest.
created/changed: Retry (Error in CONCUR Enterprise User Check! Cannot construct instance  (although at least one Creator exists): no int/Int-argument constructor/factory method to deserialize from Number value (409) at [Source: REDACTED (`StreamReadFeature.INCLUDE_SOURCE_IN_LOCATION` disabled); line: 1; column: 11] (through reference chain:
@LMAG have you submitted a help ticket to Concur Support about this?
