We are using ICS for financial posting.
As part of the interactive communication between SAP and Concur, Concur displays on Audit Trail --> Report Level --> Description the posting feedback received including the SAP financial posting document number.
Is it possible to report this information through Cognos?
@Kmilogon I don't believe the data you are asking about can be reported on in Cognos.
