gopalrathi
I do not see an option to sent a link to setup Concur on my mobile
I tried and followed as said in other articles that I would see under profiles to sent a link to my mobile.
Surprisingly I do not see as an option , Can some one help here.
Articles posted are outdated and not as per the current Concur Profile setting.
@gopalrathi so I am clear what you are trying to accomplish, are you trying to get the SAP Concur mobile app set up?
If you have an SAP Concur profile, then just download the SAP Concur mobile app from the App Store or Google Play market. Once downloaded, use the same credentials you use for SAP Concur for the web on the mobile app to log in.
