Elena2
How to export report with active users only
I am trying to export a list of all active users from CONCUR. I tried the report from standard reports - administration - Employee details. I selected to only have the active users.
Still, in the exported report, I have many inactive users.
Should something be changed in the report ?
Thank you.
Elena
@Elena2 might be easier to just build your own report.
If you add Employee Name to the report, then go to: Expense Reports > Report Header Information > Additional Employee Details and add Employee Active Flag. Once added, create a filter on the Employee Active Flag data item to only show Y. This should then show only active employees.
Elena2
Ki Kevin,
Thank you for your reply, I will try to do that.
