I am looking for assistance with updating travel expenses in Concur. I need to determine how to change previously submitted travel expenses to a different billing code.
Could someone please provide guidance on the required process or direct me to the appropriate point of contact?
Thank you for your assistance.
Hi @bbyrd001
Topic: Help revising report as billed to wrong client
SAP Concur – Change Billing Code on Submitted Expenses
If the expense has already been billed to the wrong client, correcting the accounting entry alone may not correct the client invoice.
Finance or Client Billing may also need to issue a billing adjustment.
For Correct unprocessed expenses in Concur, use Finance/Accounting for posted transactions and Client Billing for invoiced charges.
Pending reports may be corrected in Concur.
However, fully processed expenses require Finance intervention.
Report Status | Corrective Action |
1. Submitted / Pending Approval | Recall the report if permitted, or request its return |
2. Returned to Employee | Correct the Client/Billing Code and resubmit |
3. Approved / Pending Processing | Contact the Expense Processor to determine whether the report can be returned |
4. Processed / Extracted | Contact Finance for an accounting correction |
5. Posted to Financial System | Finance may need to perform a journal reclassification |
Where to Change the Billing Code?
Navigation: Home → Expense → Report Library → Open Report → Select Expense → Allocations or Expense Details →
Update Client/Billing Code → Save → Submit.
The exact field location depends on your Company's Configuration.
Thanks & Regards
Samantha Prathikantam
