greenwalt
Expense Report descriptor
Is it possible to add some verbiage around the 'Expense Reports' area on the Concur homepage?
@greenwalt out of the box, this is not possible. However, I believe  if you were to use the buy-up version of WalkMe, this is possible.
Frequent Member - Level 2
Hi @greenwalt ,
I think this is not feasible. This is a standard system design and there is no scope for any customization.
@KevinD - Can you please confirm on this point.
