jguay
Concur is down?
We are unable to connect to Concur nor Open Concur. Is there a problem?
Trying connecting to Concur:
upstream connect error or disconnect/reset before headers. reset reason: connection failure
 Trying opening Open Concur: error while generating code.
Thank you!
@jguay there was a disruption. Are you able to log in now?
jguay
Yes, it's working now.
