VOK
Concur Vehicle API - mileage_vehicleId
Hi, The ExpenseEntry V4 API includes the mileage_vehicleId field, but that field on its own is of little value because there doesn't seem to be any way to get the details of the vehicle using the mileage_vehicleId. Is there a way we can get the Vehicle Information via API so we can understand what vehicle it is that was selected during the Expense Entry input by the Employee.
@VOK my API contact said he has no idea. Most likely, it isn't on the Roadmap then.
@VOK my API contact told me this feature isn't developed yet.
VOK
Thanks @KevinD , Do you know if its on a development roadmap? Our implementation partners told us back in 2023 that Vehicle API was due in 2025 but still no sign. I appreciate roadmaps can change or be miscommunicated, but I'm hopeful it is on someone's to-do list or is that wishful thinking?
