Mico
Concur Transaction Below Minimum Claim Amount
Hi, I’ve received a reminder from the Concur team regarding my corporate card account, and I currently have a transaction pending for submission.
However, the transaction amount is below the minimum claim amount of S$50, and I don’t have any other transactions to submit at the moment.
Could you please advise how I can submit this transaction below the minimum claim amount? I’d like to avoid any delay in the settlement process and prevent receiving a non-compliance warning due to the transaction remaining unsubmitted.
Appreciate your support in advising how I can resolve this issue. Thank you!
@Mico that error isn't a Concur Team reminder, it is a reminder set up by your company. I believe the only way around it is to incur other business expenses and add them to this report to push it over the $50 limit.
There isn't anything we can do to help as this rule/requirement is one created by your company.
My only suggestion would be to speak with your direct manager, but a rule like this isn't something usually doesn't have any workaround.
Unless you have a submitted report that isn't fully approved that could be recalled where you could add this transaction, I believe there isn't anything you can do other than wait. You could reach out to the team at your company that issues company cards and ask them, but I don't know if they will tell you anything different from what I've said. It is worth a try though.
I've honestly not seen a rule like this created before and I've been at Concur getting close to 18 years.
