May_saeed_alre
Concur Theme - User Interface
Greetings all,
I would like to know how can I change/adjust the Concur Theme - User Interface.
I want to apply the company colors, logo in the background, change the buttons colors...etc
May
JessicaL
If you have the correct permission set, you can customize your "Company Info" section to show your company log and add contact information. This can be found through Administration --> Expense --> Expense Admin.
If you also have Travel enabled, though, you would have to go through Administration --> Travel Admin and then, to the Custom Text tab.
Hope this helps,
Jessica
@May_saeed_alre of the items you mentioned, you can only add your company logo so it appears above where you see your name when you login to Concur. As for changing the UI Colors and buttons, that is not something you can customize.
