melanieG
Concur Support unavailable
Concur support has been down all week - I already cleared cache and cookies, but it didn´t help.
Is anyone currently experiencing the same issue?
Are there any updates, when the service will be available again?
Thanks and best regards,
Melanie
@melanieG are you still having the issue? Did you try calling Support?
leela2516
@melanieG - I have had no issues. As a matter of fact, I opened a case with them day before yesterday and was conversing via the case yesterday without issue.
melanieG
Hi Kevin, yes the problem is solved.
I´ve asked  a colleague to contact the support on my behalf and they were able to fix it.
Thank you!
