BABLISAR
Concur Support Portal
Hi all - newish to Concur.
My colleague has raised a case with Concur.
Am I able to view it/contribute to it?
Found some guidance online suggesting I should see something like this:
But I can't see how to get to it?
@BABLISAR I am not sure if you will be able to see cases other people have created. That may only be something your site admin can do. However, I do need to add that I don't use our Support Portal, so what you are asking might be possible, but we would need another Community member who has used the Support Portal to verify.
