Hello -
We use Concur Request (not integrated with Travel) and I'm looking for reporting of the requests submitted in the last year and I can't find anything in Intelligence. Does anyone know where or if there is reporting for Request?
@kgrate give this a try. Open Cognos, start a new report. Above the data warehouse, use the Search field. Type in Request and see what it returns. You should see any data items that have the word Request. If you mouse over the data items, it will show you the path within the data warehouse to find that item. By the way Authorization Request is another term for Travel Requests.
