ktlnboyd
Concur/Netsuite accounting question
We are just starting out with Concur and are working on our NetSuite integration.  Do we need a separate AP GL Account just for Concur?  What are the pros and cons of using our regular AP GL Account versus a dedicated AP GL Account for Concur.
@ktlnboyd I suggest posting this (if you haven't already) in the Admin Group. You are more likely to get a response there. If you aren't yet a member of that group, go the group and use the Request to Join option.
ktlnboyd
Thanks for the tip!  Waiting for access.
