I cannot login to Concur from Edge for the last few days. From Chrome I dont have issue.
Does anyone facing the same issue? The message shown on the Edge is "MS will terminate IE11 on Win 10 environment. SAP Concur also need to transform from IE11........" I am not using IE11, I use Edge.
Thanks if anyone help me.
