mcaisucar
APIs for user integration
Hi Team
I was checking on the integration with Concur with the user management point of view.
Our requirement was to get users ,roles from Concur system along with creating new users ,updating existing users.
I could see 2 modes of integration
a) https://api.sap.com/api/ConcurIdentity/resource
which talks about the V4 apis.
/v4/users/lookup
b)https://developer.concur.com/api-reference/profile/v4.identity.html
https://us.api.concursolutions.com/profile/identity/v4/Users
There is a note mentioned
Important: This API is currently in pre-release status and is only available to approved early access participants. The API is under development and might change before being generally released. To become an early access participant, contact your SAP Concur Representative.
Wanted to check what's the difference between both the modes and which API will fulfill  the use cases.
Regards
Manoj
@mcaisucar I suggest posting this in the Admin Group. You are more likely to get a response there.
mcaisucar
Hi @KevinD
Thanks for the response.
I am getting access denied when i try to post it on Admin group.
Any clue why.
Regards
MAnoj
mcaisucar
@KevinD Can you please help us here
