YIsaacs
Not receiving Concur Travel Itineraries after booking
Anyone else having issues not receiving the Concur Itinerary after booking?
JessicaL
Hi @YIsaacs,
Have you ever received an itinerary before and this is a new trip that you did not receive one?
If you have never used Concur Travel before to book a trip, some of our users experienced this problem. However, once they verified their email address in their profile, they were able to receive them.
Profile --> Profile Settings --> Email Addresses
Under the column "Verify", Concur will send an e-mail with a code that you then put in this location.
If you have already done that, it may be an issue with the TMC and/or Concur - depending on when you booked, I know there were a few partial outages and/or maintenance going on last week.
Hope it helps,
Jessica
QLDTravel
Hello
I am having the same problem, but, it only started happening yesterday and today. I have always received the "Concur Itinerary" before the Ticketed & Invoice came through, now I'm only receiving the Ticketed & Invoice. Can you please advise if there has been a problem the last couple of days with the system. Thank you in advance, much appreciated.
YIsaacs
Hi - you replied to a message from 2018, but we are not having any current issues.
QLDTravel
Hello - so how do I fix this issue. I'm still not receiving the standard Concur Calendar
email after booking and I checked and our email address is definitely added into the bookings, can you please advise further.
@QLDTravel there was a system degradation on Tuesday. Maybe that was the cause.
QLDTravel
Hello, even after the degradation, I'm still having the same problem, even today. I just finished booking a flight and the Concur Calendar Itinerary did not come through.
