In my Profile I have the correct ID for National, when the reservation comes thru it shows another number. Where do I start to have this corrected?
Thank You...
@DRM by correct ID are you referring to your rewards program number with National?
This is affecting me also. For a trip I took in July I had to call National and tell them my reservation number. They were able to add my member number and bang, it showed up in my app. I'm traveling again next week and have the same issue, my reservation does not show up in my app.
@mlefevers so I'm clear, you have a National frequent traveler number entered on your Concur Travel profile or no? If not, try adding it and see if that works.
Hi Kevin. Yep, my National number is in my Concur account. Its only National I'm having an issue with. Southwest Airlines and Marriott work just fine.
