Dear community,
I use concur to manage the business travelling for my colleages. They had a really bad experience with a hotel in Paris this week.
Is there an opportunity to block a hotel in concur, so when we search the next time for a hotel in the same City, it will not be shown anymore as a suggestion?
Hope you can help, the hotel had bedbugs...
Best regards
Sandra
@SandraBock In the Travel Rule builder you can tell the system to not show results for certain vendors. What is the name of the hotel? Let me see if it appears in the vendor list supplied by the Travel Rule builder.
Dear Kevin,
thank you for your response! I actually don't know where to find the Travel Rule builder to be honest. Could it be that maybe I do not have the rights to do this and that's the reason it is not showing? Is there maybe a step-to-step guide?
The hotel was "Timhotel Paris Gare de l'Est [HRS Clean&Safe]".
Best regards
Sandra
@SandraBock there is a very good chance you don't have the permissions to make these changes. Let me see if that hotel comes up in the list of vendors in the Rule Builder. If the name doesn't, we would need something very unique to look at in the hotel description to block it without blocking other hotels.
Thank you Kevin!
I also need to do this with a Hotel. Can you advise what action you took or how you resolved this?
@crapprover12 if you have access to the travel rule builder screen, you can select Hotel from the Template drop down field. Click OK. Next click Add. From here you will see a list of conditions with checkboxes. Look for "Hotel property is one of". Check the box. This will make the condition appear below the list of options. In the field you will need to enter the hotel property ID. Click Save. Next, go to the Travel Admin screen. On this screen look for Hotel. You will see an Edit link. Click the link. On the next screen, you will see the rule you created. Be sure to check the box next to the rule to activate it. Then, using the drop down, select either Hide or Show but do not allow. Click Save.
That should do it.
@crapprover12 - in addition to what Kevin already shared. You can also add the vendor to the exclusion list. Here are the steps.
To exclude a vendor kindly follow these steps:
Click Administration > Company > Company Admin
In the Travel Administration section of the left menu, click Travel Admin, the Travel Policy Administration page appears
Click the Travel Vendor Exclusions tab
In the Travel Configuration list, select the desired configuration, the page refreshes, showing the excluded vendors for the selected configuration
Look for the desired vendor Air/Hotel/Car
To hide the vendor from the search just Click on the box next to the vendor
Click Save Settings
@leedau I went in to look for the Hotel section and it looks like you can only block at macro level. For example I couldn't find thedarcyhotel.com in any of the lists. We're trying to block properties which charge 'resort fees' in addition to the nightly rate, the resort fees do not get quoted when booking but show up when checking out.
@crapprover12 if you know the property id, you can prevent it from being selected. You want to use the Hotel property is one of then enter the ID. Now, your next question might be, where do I find the property ID? That was my question as well. There is something called Hotel Fixer and the GDS logs will show the property ID. I'm not familiar with either of these. They are just what I was told. 🙂
