is the TSA PreCheck iD number the same as the Nexus Card id number?
If not, can the nexus card info be entered?
@kss007 I believe Nexus is for entering Canada and therefore it would not be the same number as your TSA pre-check ID.
Will there be option to add Nexus information in Profile? Nexus includes TSA Pre-check as part of its membership. And includes benefits of Global Entry.
@covenant I've not heard anything about this being added, but I'm also not on the Travel product team. I posted this question internally to see if anyone can tell me if this is on the roadmap or not.
After speaking with Concur support, you can enter the Nexus Pass ID as KTN. It does work. I have booked several trips and Pre-check is automatically included when you check in to the airline.
@covenant thank you for the update. This is good information for not only me, but others. 🙂
