smaritzas
Forecast Report for concur travel solution
is there a way to download the forecast travels? I will need depart+return+destination by person.
No need to download the Actual expenses.
Sandra
cjmarimo
Hi @smaritzas
In Analysis/Intelligent-Cognos, in folder Team content->Analysis-Stardard Reports->Travel Request you can find the "Travel Request by Segment" report, where you can put filters by Segment Type and Start Date
when you execute report, the result you can save in differents formats
It's possible "Approved Travel Requests by Employee" report is more useful for you.
BR,
cj
smaritzas
Thanks cj,
I do not have access to cognos, but I am currently using the Travel Arrangers area, manually downloading the data for the upcoming travels:
Does it exist a report like "upcoming Trips"?
Also, can it be set up to be automatically send by the system to an e-mail?
TriciaW
@smaritzas  There is a Travel Report called Employees Traveling Today within the Concur Standard Travel Reports that will show you all of the upcoming trips of the employees in your company based on selected search criteria.  Report User permission is needed and the Report Name assigned by the Reporting Admin for your Company will allow you to be able to access and run the report.
Tricia Whipps
SAP Concur Select Care Community Moderator
