I am traveling to two locations. How do I enter multiple cities on my concur request?
@ewild it appears you resolved the issue. Correct?
Can you please post the solution/answer? Thank you.
Hello
I have the same problem
I have only two options : One way and Round trip.
How I can find multi city trip ?
thanks
@Aymen__DA Thank you for your post in the SAP Concur Community. Can you provide a screenshot of what you are seeing? Are you looking for multi-city when searching for travel? I am not able to assist until I know what you are seeing.
I look forward to your response.
Here is Screen SHOT
as you can see no option to chose multiple City Trip
@Aymen__DA Thank you for your follow up post. I was able to look at your configuration and it appears that your company currently has the Multi-City option disabled.
When you log into SAP Concur, you should see the contact information for your Travel Agency under the Company Notes section. They should be able to assist or provide direction.
