SAP Business Exchange
reberts
Why does the same query provide different results?
I've been learning the Concur Travel system for my job, and it strikes me as very strange that, when I enter the same query multiple times, it gives me different results every time I hit search.
Why would the system give me different results for exactly the same query?
I don't trust the system to provide me with accurate results if the results are not the same when I haven't even changed the query.
1 Reply
clayw1963
Re: Why does the same query provide different results?
What query are you trying to run?  Do you get different results on every query that you run or just one particular query?
Clay Wilson
