m-thomas
Network Connection Error
Cannotl log into the SAP Concur App at a sudden. Error Message "Network Connection Error". What do I need to do to make it work again?
nicolaswehmeyer
Re: Network Connection Error
I am getting a Network Connection error when trying to login within the app. I have tried installing all the latest iOS updates, reinstalling the application by deleting it and downloading it again to my Apple devices (iPhone 6s Plus & iPhone 7), but nothing fixed it. Did the last update maybe break the login functionality?
Is a fix planned? I need the app to submit my receipts to concur.
Thanks in advance,
Nicolas
gunther_manz
I get the same error - Trier it on different devices from Apple can‘t Login. Every Time the same Network Connection error
please fix it - Not Abel to Upload Ana expenses
moptland
Exactly the same error message. Have been using Concur on iOS without a problem. Suddenly I had to fill in my email address, and then the Connection error message appears - not even entered my password yet.
Deleted app, reinstalled, no solution.
10162962
I tried reinstalling the app, hard reset but I still get network connection error when opening the app. When is a fix expected?
nicolaswehmeyer
Guys, I think the issue has been fixed! I tried it this morning again and could successfully login from my Apple devices again!
Thanks!!
Hey Team,
There were some issues I read with the connectivity, I also tried to submit my Expenses! Things should be almost back to normal now. If you do notice anything which isn't working as it should, have a chat with your company admin who can investigate and open a case with Concur if needed.
Kind regards,
Angus Irvine Robertson
SAP Concur Customer Experience Transformation
matt24
Hi Angus/all,
same error ‘network connection error’, can’t see to find any solutions or fixes on here - please advise if I have missed?
also how do we find ‘the champions’, there are no obvious support links, (apart from an online manual) on the Concur site!?
i hear lots of excited colleagues to get the app functionality but alas not able to enjoy due to the aforementioned issues.
thanks
