lleung
Rental Car Company Options
So with the new updated Concur, I can only choose between Enterprise and Avis as my rental car company of choice. But sometimes when I loaded to the old Concur page, it gives me all the rental car companies to choose from.  Could someone please explain this?
TS1
You might need to filter. If that doesn't work, then they are blocked, and you should ask your company's travel manager why they decided to block the other companies from showing up. This is something your travel manager can get fixed if it's not supposed to be so.
lleung
I don't believe it is blocked. When I go to the new Concur, I get fewer selections. But if I can somehow get to the old Concur, I can select from more rental companies. Is there a trick to force the computer to load the old Concur page?
@lleung there isn't a trick. Once your company has moved to the new Concur Travel, that is what you will see.
You may want to call your company's travel agency and ask them about this. Maybe with new Concur Travel, your company put some travel rules in place.
