je1077
Concur system error message when booking a flight/hotel
Hi, I'm writing to request an urgent assistance with a Concur booking system error that I'm currently facing. I've attached a screenshot for your reference.
I'm trying to book a flight/hotel for my trip, but I'm consistently encountering an error message. I've already tried troubleshooting steps like restarting my laptop and adjusting my search criteria, but the issue persists.
I would be extremely grateful if someone could please assist me in resolving this issue as soon as possible.
Thank you for your prompt attention to this urgent matter.
@je1077 if this is still occurring then I would recommend calling your company's travel agency to get the booking completed. Then reach out to whomever at your company is your travel administrator. There might be some contact information in the Company Notes section of the SAP Concur home page.
9 REPLIES 9
Lindasisung
Its a Concur issue-- old system that is hard wired and can't be fixed as per Concur team , Kevin.  There are over 17 reasons that Concur error message is triggered and it does specific which of the 17 reasons the error was triggered..
annakozicka
Hello, can you please help urgently?  I cant book a flight in concur due to the error:
https://screenshot.googleplex.com/7SL6ysxCtZwRFXF
I can do nothing to fix this. Can you help?
je1077
Thank you for your prompt reply.
I've already reached out to the travel agency's support team, and they were able to resolve the issue.
Thank you for your assistance.
Best regards,
Jade
Lindasisung
Kevin: we see this often and from what I’ve experienced and learned, Concur cannot tell the end user what the error applies to because this message is hardcoded and is triggered and applies to 18 or more possible reasons for the trigger. That said, Concur has not found a work around for letting the end user k own what caused the problem. Kevin you/Concur should be able to provide that list of reasons that trigger this error message.  I would like to see Concur make more of an effort to fix this problem rather than respecting to the TMC for resolution. It’s clearly a problem w how Concur had hard coded but not offered solution at the time of booking.  Until Concur can recode, this problem lives on.
wallacd9
Having same issue and totally agree with your comments. Passing the buck and not fixing root cause it seems. In meantime, hassle for everyone.
rdwarr10r
Recently, I've encountered the same issue numerous times. It isn't convenient to call someone every time it happens although it seems like if I've reached a certain point in the booking, I can return to the homepage and continue where I left off.
ts65614
Its actually very concerning, i book the travel for all of our employees and 50 percent of the time i run into this issue. I reach out to our travel agents and they get it booked no problem. But we are then charged service fees. So this platform's issue is costing our company MORE money because SAP cannot get this issue resolved.
shigginskirby
100% this and the above posters also. we encounter endless 'error' messages and are told that either the system timed out or they can't find any issue and the travel agent is always able to make the booking on our behalf. we incur higher fees for bookings that we should be able to make. Concur really needs to code their error messaging better. as the poster above said, there are different error messages returned which will be for the same issue (as per Concur support feedback) and then we will receive error codes that are nowhere to be found when we search in the Concur support resources. There are are surely a limited number of reasons that a booking can fail/stall and it can't be that difficult to code them with adequate and descriptive wording.
We are now with the last 2 weeks facing a constant recurrence of issue 'your booking is in progress'. sometimes the booking appears in the trip library a few moments later, sometimes not at all and doesn't get booked anywhere and other times it's booked with the vendor but we have not sight of it on Concur in trip library. it boggles the mind. so frustrating
