Jan10e
Concur Travel reporting
In 'Travel reporting' there are a few tools I use quite often and some I never use. Does anyone know if it's possible to group the tools that you use on a regular basis? E.g. create a list with favourite tools. Thank you!
@Jan10e by "tools" do you mean the reports you can run?
Jan10e
Hi Kevin, thank you! See screen shot. I am seeing 'recently used' but it would be good to have a favourites bar/ selection. Or a frequently used  selection.  Does such a thing exist? ( I am always searching, which option to use)
