Hi,everyone.
As I save entry with editting the total, the total gets so many zeros immediately.
And then if you open the entry, those zeros are gone.
ex)Before saving entry: Total [20,000] → After saving entry; Total[20,000.0000.0000]
If anybody knows if this phenomenon depends on settings or just the way it is.
Thank you.
@Miri I didn't see anything unusual with the field set up, however it does have a maximum character allotment of 23 characters. Not sure if that causing it or if it is a currency thing.
It doesn't seem to be negatively affecting anything though, right?
@Miri do you have the name of an invoice I can look at to see if I have the same issue?
@KevinD
I see.
→No, it doesn't. My client was just wondering the phenomenon.
I appreciate your cooperation.
