jgriffin
Invoice extracted
Good morning.  What does it mean when my invoice status is set to extracted ?  Thank you.
@jgriffin I believe that means extracted to be paid. Basically it has received final approval.
nmagalhaes
Hello @KevinD Do you happen to know what process actually updates the status to extracted? It seems that in our system this is done automatically by System, Concur. Thank you.
Nancy
@nmagalhaes yes, I can see that, but for that automation to kick off, the processor must approve the invoice.
