GodfreyC
ERRORS: Importing Purchase Orders and Purchase Receipts into Concur
We sending Purchase Orders and Purchase Receips into Concur, we have had issue with errors but getting better. My current need is
"Error Code: 1001; Error Message: The External ID is missing or invalid. "This is basically, PO#-PO_LINE#", data looks okay to me
200,644481,644481-72,937737,937737-72,,1,2020-02-06,,,,,,,,,,,,,,,,,,,,,
Thanks is Advance
7 REPLIES 7
AshleyB
SAP Concur, Former Employee
Hi @GodfreyC
Thanks for posting! Have you created a support ticket for this issue? Our support teams should be able to look into this for you.
Ashley Bragg
GodfreyC
We did but taking long was thinking someone might have experienced the same problem.
AshleyB
I see. Well, good thinking to check with the community! I look forward to hearing from our members who might have experienced this as well.
Ashley Bragg
Karthikhemadri
Hi @AshleyB or @GodfreyC
can you provide how we can get the policy external ID to import PO's.
Hi! The policy external ID is unique to your PO Policy. Please contact support to get that information as you would not have access to the policy on your side.  Thanks!
Karthikhemadri
@MelissaS i figured it out on where to look for policy external ID. just for other facing the issue - Open the Policy setup which is currently active for your group config, scroll down to the last, you will see the external ID details.
champa
Hi GodfreyC,
Thanks for posting here. Could you please let me know how you got this error fixed?
Looking forward to hearing from you.
Champa
